Wheelie22
419 Vistas, 7 Respuestas
mirrtext = 1
Al texts are bold when mirrored on screen and in the plot preview :
Using AcadE 2022 with all updates.
And these solutions don't work :
Text-appears-bolder-than-expected
yes, this works :
TTF Fonts Adjustment:
  1. Switch from TTF font to SHX font.
But I need TTF  !
cadffm
en respuesta a: Wheelie22
Share THIS sample, please (.dwg AND .pdf)
Sebastian
Wheelie22
en respuesta a: cadffm
Test it please.
cadffm
okay. All fine, that's the best you can get and there is.
Your PDF "can" looks fine, use another Viewer or different settings.
My Scrrenshot of YOUR PDF:
In AutoCAD, mittored TTFs thru viewports: You can't change it.
You will see it in some situations (Zoom levels) that mirrored are displaying thicker.
(Paper)Plot, no problem.
Sebastian
Wheelie22
No no, don't be so positive. I see it on your screen shot to, with a lot of zoom in. :cara_que_disfruta_de_una_comida_deliciosa:
Looks like the width is set to 0.9, that always looks terrible.
But ok,
if customer accepts then
  accepted solution
else
  goto start
end if
 Print :
Do you use another AutoCad version ?
cadffm
With which program you can zoom in by keeping the quality good enough?
But okay, all I want to say is: You can't change anything, except to use another viewer or another setting in your viewer.
again YOUR pdf, compared in different programs.
>>"Do you use another version ?"
For what?
In my answers I talked about your PDF!
But be sure, it is the same on my side, if I use the same AutoCAD version as you (2022.1.3)
Sebastian
Wheelie22
If you use a TTF font you can zoom to atom size and it is still smooth.
cadffm
But I didn't offered any data with any Text object inside,
just a stupid rasterdata file (screenshot), that's why I asked.
Sebastian
