laraujo
533 Vistas, 3 Respuestas
No matter the scale I use HATCH keeps white solid
I watched videos, people changing the HATCH scale and the HATCH changes, but mine will not change no matter i use 0.001 or 10000. Keeps white. It is a layer of poor concrete below a foundation. Thank you very much.
davinatkins
en respuesta a: laraujo
The only hatch I see in this drawing is at the bottom of this footer (?) and it's working with the hatch scale option just fine. Is this the area that you are asking about?
Kent1Cooper
I am able to change the angle, the spacing, the color [I made it red here]:
Are there any messages when you try to change it?  Does it make any difference if you change it to not be Associative?
Kent Cooper, AIA
cadffm
pattern ANGLE is set to 1, needs ~ 0.01
pattern Ansi31 is set to 1000, needs ~ 0.01
pattern _User is set to 0.1 and IS visible well
Sebastian
