02-15-2024
05:14 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-15-2024
05:14 AM
Try this:
Recovering a backup (BAK) file:
- Open the folder containing the DWG file.
- Look for a file with the same name as the one to recover and a BAK extension.
- Change the BAK extension to DWG.
- Open the file in AutoCAD.
Recovering an autosave (SV$) file:
- Open the Autosave folder. On Windows, it is in the Temp folder by default. You can open it by typing %tmp% into the Start menu.
- Look for a file with the same name as the one to recover, a timestamp code, and an SV$ extension.
- Change the SV$ extension to DWG.
The error message you’re seeing might be due to a few different reasons:
- Invalid File Paths: AutoCAD was installed into a custom directory location, but the DWG Common registry key points to the default path. You can try to edit the Windows registry.
- Missing Files: The drawing file for the symbol is either removed or not existing in the configured search paths. You can check the symbol inside the Icon Menu.
- Corrupted Files: If the file is corrupted, you might not be able to open it. In this case, you can try to recover the file.
