Basam.Yousif
714 Vistas, 10 Respuestas
How to import a PAGE SETUP into multiple DWGs
Use Autodesk's DWG TrueView program (which -I believe- is a free download)
https://www.autodesk.com/products/dwg-trueview/overview
ennujozlagam
en respuesta a: Basam.Yousif
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-AD77C304-90AC-43E2-8380-434FFEF7C4D7
cadffm
if you like to share such tips without reason, look at this format too.
https://forums.autodesk.com/t5/autodesk-community-tips-autocad/tkb-p/autocad-tips-tricks
Just one point: Avoid to show changes of standard predefined setups, create your own.
And: If AutoCAD is available, it is onboard, command: DWGCONVERT
Sebastian
Simon_Weel
The screenshots are about 'DWG Convert' (which is called eTransmit in AutoCAD) - not Pagesetup? So is your question about Pagesetup or DWG Convert?
cadffm
en respuesta a: Simon_Weel
No, the command equal to is DWGCONV, etransmit doesn't have the same possibilities,
and another point: DWG Trueview is for free, for AutoCAD internal commands you need AutoCAD (and a license)
It wasn,t a question, it is a tip for people who don't know this option.
Sebastian
Michiel.Valcke
Not sure if it's possible in trueview, but with batch plot (publish) you can set the pagesetup from your first chosen sheet and then apply it to all the other sheets in the list even if they do not have that pagesetup in their document.
cadffm
en respuesta a: Michiel.Valcke
In publish command you can do this for the plot only, it doesn't change your layout pagesetups in your DWG.
in DWGconvert (in TrueView) you can change pagesetups in your DWGs files for (all) layouts.
Sebastian
Basam.Yousif
This is a How-to post, not a request for help. Thank you for all your feedback.
dany_rochefort
@Basam.Yousif  I've wrote a lisp command that does this in 1 second.
dany_rochefort
FYI: Writing a How-to-Post and accepting your own post as the Answer is a bad look.
WeTanks
en respuesta a: dany_rochefort
@dany_rochefort
Could you please share your LISP file?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
