leeminardi
en respuesta a: grenier4
How did you make these "lnes" that do render?
Are these lines or solid cylinders?
3ds Max has a feature to enable a renderable thickness for lines when displayed in a viewport or rendered output.   I do not believe that AutoCAD has this feature.  The .dwg file can be imported to Max and then rendered but you would need to assign materials and define lights in Max.
Note, lines, polylines, and splines are 1D obects that exist in a 3D space.   They are considered 1D as it takes only one paramter to locate a point on them as opposed to a flat or sculptured surface which requires 2 parameters (u and v) relative to the object.   The located point will have 3 coordinates to describe their location in the 3D world.
lee.minardi
