Kent1Cooper
en respuesta a: yu85.info
@yu85.info wrote:
.... in my case the number of vertex is not to same. So I had to do it manually. ....
That seems the only possible way, under the circumstances.  You would need to make choices about which vertices you assigned which values from which vertices of the other Polyline, if they don't match up one for one.  Maybe if you could define some criteria for determining that, it could be automated, but it's hard to imagine.
Kent Cooper, AIA
