- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Purging Reg Apps in autocad drawing.
Hey does anybody else run into the issue of purging reg apps in AutoCAD. Then it says it purges out ACAD_OBJECT_CHANGE_GUID then when I come back into drawing a I do purge reg apps again and ACAD_OBJECT_CHANGE_GUID returns any suggestions?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
your product and productversion is?
you are saving the file in native format, or in an older one (which one)?
Xrefs attached?
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No, but it's a good information too!
I asked about the file format (version) you are using.
dwg2018 is the native file format,
dwg2013 is an older format..
3D, so you are using 3dsolids?
Could be related to solid history.
Hmm
But hey, it isn't a problem.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is your DWG file totally devoid of blocks and 3D objects and anything other than lines, plines and arcs?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I think you saving the file in an old .dwg Format.
Try this
Command: SAVEAS
Use a new name, to keep the original file
and change the file format to Autocad drawing deg 2018 format (Q: What is the default format in this moment before you set dwg2108 ?)
Try purge reg and save/close/ reopen the file
Still the same?
Sebastian
