Kent1Cooper
en respuesta a: mattdVF27J
@mattdVF27J wrote:
.... I wish you could set rotate default to reference. I had a lisp that was doing that, unfortunately it was gumming up ACAD to  crawl. ....
[By the way, you must have used the Reply to the topic... slot that appears below the last Message.  Things posted there always show as being in Reply to Message 1 and the OP.  Instead, always use the REPLY button at lower right within the Message you're Replying to.]
There are probably multiple command definitions around that build in the Reference option.  It is such a simple thing and a short command definition that it seems very unlikely to be the cause of gumming up.  But even if it was under whatever definition you were using, maybe you can find one that doesn't do that.
Kent Cooper, AIA
