amjadmXVPEC
175 Vistas, 2 Respuestas
Working with Excel Data Link
Is there a way to create different tables in AutoCAD from the same Excel Data Link, whether the link was the entire file or a range?  For example, one table shows the range A3:D9, while another table shows the range C10:G12, etc.  Right now, the only way, I can do this is be creating several Data Links from the same excel file, based upon the range of cells to be used in different tables.
rkmcswain
en respuesta a: amjadmXVPEC
I think you have to consider the term "Data Link" to include not only the source file, but the range also, so AFAIK, what you are doing is the way.
amjadmXVPEC
Thank you, RK.  Hopefully, AutoDesk will add further options for utilizing linked Excel files.  Cheers!
