fdeldjouiMEQKR
321 Vistas, 5 Respuestas
Text Orientation
is there a way to have a smart TEXT to the in a viewport so they would not upside-down. I understand if "Match text to the orientation of viewport" is selected, Text will display horizontally to the orientation of the viewport, but we don't that, we want to avoid text to display upside down. this would be very useful for instance to display the Boundary labels which they need to align with the direction of Lines and Arcs not the Viewport.
paullimapa
en respuesta a: fdeldjouiMEQKR
Sounds like a great wishlist feature. You can send to Autodesk here
https://www.autodesk.com/company/contact-us/product-feedback
Paul Li
IT Specialist
@The Office
mattdVF27J
this is exactly the kind of thing keeping ACAD in the past. Amazing to me that in 2023 we have a program that cant auto align text when default orientation is clearly not the direction you want when rotated. I was blown away when I discovered that ACAD forces me to flip/mirror txt in those instances. I've come to learn to work around things like this but there is some low hanging fruit that Autodesk you would think could tackle. To many extra steps in many simple process. Rotate is another. I find myself using reference in rotate almost 98 percent of the time, yet the default rotate requires the extra step of determining a reference if your not snapping to 0/90/180/270
Kent1Cooper
en respuesta a: mattdVF27J
@mattdVF27J wrote:
.... I find myself using reference in rotate almost 98 percent of the time, yet the default rotate requires the extra step of determining a reference if your not snapping to 0/90/180/270
[You can at least reduce the need for that extra step, by having Polar snap turned on [F10 key] and a POLARANG setting that suits typical rotation angles you would use.]
Kent Cooper, AIA
mattdVF27J
Agreed. However Im never using typical rotations. The item or text could be sitting at an abstract angle and reference seems to always be required. I guess for many maybe default angles ins the go to but reference gives you full control regardless of the angle the object sits at. I wish you could set rotate default to reference. I had a lisp that was doing that, unfortunately it was gumming up ACAD to  crawl. ACAD is what it is as they say.
Kent1Cooper
@mattdVF27J wrote:
.... I wish you could set rotate default to reference. I had a lisp that was doing that, unfortunately it was gumming up ACAD to  crawl. ....
[By the way, you must have used the Reply to the topic... slot that appears below the last Message.  Things posted there always show as being in Reply to Message 1 and the OP.  Instead, always use the REPLY button at lower right within the Message you're Replying to.]
There are probably multiple command definitions around that build in the Reference option.  It is such a simple thing and a short command definition that it seems very unlikely to be the cause of gumming up.  But even if it was under whatever definition you were using, maybe you can find one that doesn't do that.
Kent Cooper, AIA
