218510820
351 Vistas, 2 Respuestas
autocad old files not opening
Autocad old files not opening mentioning that it not founded, but once i open the autocad program and select the open file option and select the required files it opens. This is the only way that i can open them. This is also the first time that it happened. I tried redownloading the program same problem. Once I downloaded any of these old files in another pc it opens normally. So, I don’t know what’s the problem.
please help me fix this problem. Thank you.
paullimapa
en respuesta a: 218510820
Nothing wrong with program or drawing files. Try solutions here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/DWG-file-type-asso...
Paul Li
IT Specialist
@The Office
ennujozlagam
try to select recover first before opening the file and see if helps?
