02-10-2016
06:59 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-10-2016
06:59 PM
Seems to work fine in Autocad 2016 SP1.
All Paper Space Dimensions created / set to "Associative=Yes".
System variable Dimassoc = 2
Save xref base
Command: XREF - Reload Xref base in Layout dwg
Command: DIMREGEN.
Is it possible that you're not editing / updating the "Associated objects" but rather creating new objects?
In other words, lets say there are to parallel lines drawn 10 units apart and they need to be 15 units apart.
If I offset one of the original lines 5 units in the xref base file and erase the original line which was offset, I've just broken the association and it will no longer update.
If I move or manipulate the original line, the association remains and updates as expected.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
C3D 2016 SP4
