Kent1Cooper
en respuesta a: Anonymous
@florisvanburen wrote:
Still some polylines aren't 'poly-ed'. Why is this happening?
And hatching behaves also very strange. ....
PEDIT and the Join option works for me [Acad2016] in the right part.  But in case this affects different versions differently, I find that the longer Polyline of that outline [the all-but-two-segements part] starts off with three vertices at the same place.  Try eliminating those coincident vertices [you can Explode the Polyline and Erase the zero-length resulting Lines and PEDIT/Join it all back together, or use PEDIT and its Edit-vertex/Straighten option to make it go from the start to the other end of that first real segment], and see whether it then works for you.
Also, Hatching behaves normally for me, with or without Joining that one outline into a single Polyline.
Kent Cooper, AIA
