01-11-2024
08:15 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-11-2024
08:15 AM
This is a head-scratcher at the moment. I can hypothesize a guess, but it's just a guess as to why this is happening.
It looks like most of your fields started as text. If you convert text to decimal, often programs will add their baseline precision. Often when you get far out in the floating point world, noise can get added to numbers. Im guessing that is why your number of 9975 has all the trailing digits. That said, i would have thought that changing the data would alleviate that issue but it doesnt seem to be the case with this.
Is there are reason you are using decimals? it looks like all your data is whole numbers. If you used that instead of decimal formatting it may help.
CADnoob
