jthompsonGJ3BH
455 Vistas, 5 Respuestas
Block Reference is Tilted in Z Axis
A client provided a site layout drawing that includes several hundred blocks of PV module single axis tracker "tables".
Each of these blocks are titled or rotated in the Z-Axis. If looking from the left point of view on the view cube, they are not parallel to the axes and tilt up or down. See image attached.
My firm works in a complete 2D plain. I typically solve issues where clients provide 3D files by changing the Z-position of these blocks to 0. In this case, only the base point of the block goes to 0, while the remainder is still at a different elevation.
I am looking for a way forward to fix all of these blocks in just a few commands. For example, is there some kind of hidden property for a rotation on this axis that I can reset to 0? I need to keep the X and the Y coordinates the same.
I've attached an example where I modified the block in block editor to be a simple rectangle (I had to remove proprietary information from the client and their vendor). The issue must be with the block in the model space, not the block itself. No matter what edits I do, it still has this tilt.
Looking forward to advice.
On a site note, I did try the below methods, but they do not work or are not preferable.
  1. Running the commands as follows - this sends the blocks all over the drawing file at such a large scale that you can not zoom into them.
    1. (command "MOVE" (ssget "x") "" "0,0,0" "0,0,1e99")
      (command "MOVE" (ssget "p") "" "0,0,0" "0,0,-1e99")
  2. Running the FLATTEN command - this command takes a significant amount of time, it redefines each table as its own block which prevents further editing for our firm's layer standards or the ability to BCOUNT, and it does not seem to even work that well on the flatten.
