Kent1Cooper
en respuesta a: anwarsha138
@anwarsha138 wrote:
.... I need to convert this components  i mentioned above into one single plane but without exploding  ....
If you have Blocks that contain parts that are not all in the same plane, then if you don't want to Explode them, you would need to REFEDIT or BEDIT the Block definitions to flatten their contents, either using the FLATTEN command [it can be used within either Block-editing command] or by selecting things and changing all their Z coordinate and Elevation values to 0.  A routine could presumably do that for you [within limits], comparable to routines that are out there for the Searching, that do things like put all parts of all Block definitions on Layer 0, or change the color property of all parts to ByLayer.
Are there ever 3D Solid objects?
Kent Cooper, AIA
