AIR_123
718 Vistas, 13 Respuestas
Shift + Ortho
Please help. Not sure what happened, but shift as temporary override is not working as expected anymore.
Pressing shift while in line/xline command, permanently change ortho mode setting. Before it was temporary.
See below the behavior. As soon as I'm in xline/line command, I press shift and move mouse, ortho mode changes to 1 or 0 permanently.
__PRESENT
pendean
en respuesta a: AIR_123
Did you restart AutoCAD yet? Not seeing that issue here or a way to make holding SHIFT down permanently setting ORTHO unless your keyboard key is stuck down (you'll need to test with a different keyboard).
TheCADnoob
What's the string in your CUI for that override?
This is what is in mine
^P'_.orthomode $M=$(if,$(and,$(getvar,orthomode),1),$(-,$(getvar,orthomode),1),$(+,$(getvar,orthomode),1))
CADnoob
AIR_123
en respuesta a: TheCADnoob
its this
__PRESENT
AIR_123
en respuesta a: pendean
sure. even installed latest PC updates...
this happened after vacation. I don't remember I did something special in ACAD before leave...
Seems like a bug or something...
__PRESENT
pendean
__PRESENT
If its an AutoCAD bug, it seems unique to your setup so far: can you share a screenshot of your AutoCAD's ABOUT command pop-up please? If you can capture the entire RIBBON and program full window like this below that would be great too
You might end up having to RESET AutoCAD I suspect.
TheCADnoob
Is this on a laptop?
CADnoob
AIR_123
AIR_123
yes
pendean
@AIR_123 You are missing the 2024.1 Update: ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help...  start a support ticket through your subscription portal as explained here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
HTH
TheCADnoob
@AIR_123 wrote:
yes
Some laptops have issues with AutoCAD and shift Keys. The way to 'fix' that is to create a new override. That said im not certain that is your issue, but it may make for a solution. Did your laptop recently get updated?
If you plug in an external keyboard, does it make a difference?
What is your language setting set to for your OS?
CADnoob
AIR_123
@TheCADnoob wrote:
@AIR_123 wrote:
yes
Well, its the first time I have this on my laptop. I do indeed updated laptop recently, but it was after issue occurred. Update did not affected the behavior in positive way.
__PRESENT
AIR_123
Ok, thanks. I will check this update.
AIR_123
Problem seems to be solved with suggested update
