anwarsha138
927 Vistas, 20 Respuestas
autocad 3d to 2d
myself anwar and i need an answer to the following question regarding autocad file
“ is there any way i can convert a drawing with lot of lines, polylines, circles, ellipses , splines ,blocks, blocks with attributes which are seen  in different elevations. But when viewed from top it will be seen as a complete drawing like in 2d .( may be exported  from another software to a dwg file )
I need to convert this components  i mentioned above into one single plane but without exploding  cause its a large file!
any commands , any softwares where i can achieved the following
note :already tried flatshot , flatten , exporttoautocad
Etiquetas (1)
VincentSheehan
en respuesta a: anwarsha138
Have you tried the Flatten command? It's an Express Tool Command.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
anwarsha138
en respuesta a: VincentSheehan
yes. but it contain lots of elements. Blocks. blocks within blocks and all flatten is literally makking the software crash or hang. Used xplode feature but the file size is increasing exponentially.
anwarsha138
yes. but it contain lots of elements. Blocks. blocks within blocks and all flatten is literally makking the software crash or hang. Used xplode feature too
paullimapa
How’s about plotting to pdf and then in a new dwg use PdfImport command to bring that pdf back in as vectors?
Paul Li
IT Specialist
@The Office
anwarsha138
en respuesta a: paullimapa
but loosing all its details
cause as i said its quite big a file
the hatches are getting out of boundaries
i can’t attch it due to policies ..
tramber
Export and Import in WMF... a bit radical.
Or with PDF :cara_guiñando_un_ojo: or even DWF...
paullimapa
Yes you’ll lose a lot by going the pdf route but at least it’ll still be a vector dwg and some of the hatches may still be hatches.  I’d say give it a try in a smaller sample just so you can see the results
Paul Li
IT Specialist
@The Office
anwarsha138
en respuesta a: tramber
the texts are really getting bad.
I am trying with only the arch file. hope its getting better.
is there any other software which can convert this kind of dwg
Kent1Cooper
@anwarsha138 wrote:
.... I need to convert this components  i mentioned above into one single plane but without exploding  ....
If you have Blocks that contain parts that are not all in the same plane, then if you don't want to Explode them, you would need to REFEDIT or BEDIT the Block definitions to flatten their contents, either using the FLATTEN command [it can be used within either Block-editing command] or by selecting things and changing all their Z coordinate and Elevation values to 0.  A routine could presumably do that for you [within limits], comparable to routines that are out there for the Searching, that do things like put all parts of all Block definitions on Layer 0, or change the color property of all parts to ByLayer.
Are there ever 3D Solid objects?
Kent Cooper, AIA
VincentSheehan
Try to purge what you can after you explode them.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
AVCPlugins
Try this plugin too. It is much smarter than normal commands.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
pendean
@anwarsha138 wrote:
...I am trying with only the arch file...convert this kind of dwg...
If you mean the 3D content was created by AutoCADARCHITECTURE, then in that program first export "to AutoCAD" then use that file with FLATTEN command
@anwarsha138 wrote:
the texts are really getting bad....
PDF is a messy conversion option, not always great.
Doubt it. May I ask why you need a flat 2D of a 3D Architectural plan? That would help others help you better.
anwarsha138
cause inorder to insert to anothwr software
where the files should be less size and not in 3d
pendean
Which other software?
Did you do this yet
Kent1Cooper
@anwarsha138 wrote:
cause inorder to insert to anothwr software where the files should be less size and not in 3d
Those [file size and 3D-ness] are two different considerations.  A complex drawing is going to be a large file, which you may be able to reduce in size with Purging and so on, but obviously there will be a limit to how much it can be reduced.  Converting everything to 2D from 3D is not necessarily going to reduce the file size.  A 3D Polyline with Z-coordinate differences is not going to take any less memory when made to lie in a flat plane [though there could be a small difference if it can be made into a 2D lightweight Polyline].  Neither is a Block whose contents have a 3rd dimension necessarily going to take less memory when those contents are made flat.  Things like linework that have non-zero Thickness and/or Elevation can have those properties changed to zero, but they still need to have values stored in those properties even if they are zero, so no memory reduction will result.  Etc.
It sounds to me like the not in 3D must be the more important consideration, since I assume it is an absolute, whereas less size is relative.
Kent Cooper, AIA
anwarsha138
en respuesta a: Kent1Cooper
but a third party does it
i don't know how but they reduced it.
there where no blocks in the resulting dwg ,there was only one style each
,i mea the text,annotation....
i have used FLATTEN, EXPORTTOACAD ,PURGE AND ALL THAT
pendean
You've then hit the limit that is AutoCAD. Sorry.
TheCADnoob
anwarsha138
en respuesta a: pendean
it contain lot of blocks , blocks within blocks ….
elements are about 13 lakhs
