01-08-2024
08:02 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-08-2024
08:02 AM
@z5t6f193z54o wrote:
I have the same problem and can't solve it. Printing takes a lot of time in 2024, with all virtual printers (DWG to PDF, Adobe, PDF creator, etc.), the file is generated quickly but the progress window remains open at 100% for a very long time and blocks Autocad . I tried cleaning all files/folders as described by Autodesk, an installation on another computer with complete cleaning of all Autodesk installations (folders and registry): same thing!
Did you find a solution ?
Did you get a chance to try all the tips above? From your post you might have missed some.
background plotting and publishing also need to be turned off, and your 2024 needs to be at the 2024.1 update level (your AutoCAD's ABOUT command will confirm if you have it or not).
