01-03-2024
09:52 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-03-2024
09:52 AM
like this?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Editing-text-cause...
What command(s) is the other user using? And you? Find out, don't assume abbreviations (or double-click settings in CUI) are launching the same tools perhaps.
Which one of you has an add-on the other does not?
If you truly need UCS set to WORLD, then ensure PLAN command is also set to WORLD too, perhaps that's the fix you need.
Are you both using the exact same variant and version of AutoCAD? Share ABOUT command screenshots from inside both programs if you are unsure and confirm both Operating Systems versions.
