DawnAW
577 Vistas, 12 Respuestas
Mleader text rotates to north during editing...randomly
My coworker and I are working with mleaders that are rotated.  The UCS is set to world.  We are working in AutoCAD 2022.
When she is in the drawing and edits the mleader, the text display rotates (north) in the text editor and then returns to the desired location once editing is complete.  This happens if she double-clicks to open the editor or if she uses the command line.  But it doesn't happen all the time.  Additionally it doesn't seem to be happening when editing mtext
When I go into the same drawing and edit in the same way, by double-clicking or otherwise, it does not rotate during editing.
I feel that I can eliminate causes that have to do with any settings regarding the font, mleader style settings, properties, etc. since her and I are working with the same dwg file.
It makes me think that it has to do with individual system variables.  So we have tried changing editor settings on her machine with no success.
We have searched the online forums and there were others that have had a similar experience but haven't found a solution.  Could it be a glitch?  It is rather random.
Can anyone think of anything that could be causing this?
Thank you
