- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Lines won't join like horror
Horrible drawinglines won't join. What is the command to do it?
I used almost everything I know. And no other forum helps me out with this.
See the attachment, real horror. The object has to be one polyline. How-to-do-it?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@florisvanburen wrote:
Still some polylines aren't 'poly-ed'. Why is this happening?
And hatching behaves also very strange. ....
PEDIT and the Join option works for me [Acad2016] in the right part. But in case this affects different versions differently, I find that the longer Polyline of that outline [the all-but-two-segements part] starts off with three vertices at the same place. Try eliminating those coincident vertices [you can Explode the Polyline and Erase the zero-length resulting Lines and PEDIT/Join it all back together, or use PEDIT and its Edit-vertex/Straighten option to make it go from the start to the other end of that first real segment], and see whether it then works for you.
Also, Hatching behaves normally for me, with or without Joining that one outline into a single Polyline.
