832 Vistas, 1 Respuesta
Importing Autocad 2015 customized settings into Autocad 2016
Can anyone tell me how to import my customized settings from AutoCAD 2015 into AutoCAD 2016?  I thought these were synced to A360, but I'm stumped as to where they are stored.
stevetamplen
en respuesta a: Anonymous
Hi x-gbogiatzidis;
There are a couple of ways you can accomplish this:
A. MIGRATE SETTINGS FROM A PREVIOUS RELEASE TO AUTOCAD 2016
START>All Programs>Autodesk>AutoCAD 2016>Migrate custom settings>Migrate from a previous release
You would use this if both versions are on the same computer.
B. BACKUP & RESTORE
BACKUP:
1. START>All Programs>Autodesk>AutoCAD 2015>Migrate custom settings>Export AutoCAD 2015 settings.
2. Click the EXPORT button.
3. In the Export custom settings dialog box, select a location (like your desktop) to save the ZIP file created by the program.
This is the file that you would save to A360 so you can access it later, or copy to a removable drive to move settings from one computer with AutoCAD 2015 to a different computer with AutoCAD 2016.
RESTORE: START>All Programs>Autodesk>AutoCAD 2016>Migrate custom settings>Import AutoCAD 2016 settings.
Point the program to the file you created previously.
If this solves your issue, please Accept as Solution. If not, please reply back for further assistance.
Steve Tamplen
Technical Support Specialist
