Kent1Cooper
en respuesta a: m_abdullayeva2
The LINE command always "keeps asking me to clarify the end point," asking for the next end point, so you can draw multiple end-to-end contiguous Lines in one command.  Just hit Enter when you're done, even if after drawing only one Line.
As for the "it doesn't do anything" part, could you be Zoomed out so far that the Line is just too tiny to see?  Try this to check whether it did anything:
LINE
{pick a start location}
{aim the cursor in the direction you want to go and type in a length}
{Enter to complete the command}
LIST
Last
{and another Enter to complete selection}
Does it report that the Last object is a Line, and of the desired length [along with all the other information about it]?
Or instead of using LIST after the LINE command, try:
ZOOM
Object
Last
Now can you see it?
Kent Cooper, AIA
