AVCPlugins
en respuesta a: giscivil92
Attributes in model space are meaningless because they can easily be replaced by simple text or drawing properties. The attribute is needed specifically inside the block to store all kinds of auxiliary information about the product or part that the block represents. You must first add all the necessary attributes to the block in the block editor, and then insert links to the block and edit the attributes as needed without going into the block editor.
And inside the block editor you will see all the attributes, even invisible ones. And you can select one or more attributes and configure all their properties in the properties panel. There you can configure both the Tag and the Default Value, as well as important options such as Visible, Constant.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
