12-25-2023
02:33 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-25-2023
02:33 AM
Yes, of course, when you click on any element of a block, the entire block is selected. This is fine. Next, look in the properties panel - all non-constant attributes will appear there and you can edit the attribute value there.
Also try double clicking on the block and try use a context menu. Choose which method is more convenient for you.
By the way, there is a plugin that allows you to create invisible attributes directly in the properties palette, without entering the block editor.
