pendean
en respuesta a: jakeQTGYV
@jakeQTGYV Are you familiar with the difference between a crossing window (not in your video) and just a regular window selection (your video) in AutoCAD? Your video is only showing one instance.
In AutoCAD, in general terms, if you can see it you can select it with the correct selection method (and if it's on an OFF layer but not a FROZEN layer you could still select it too).
And then sometimes having layer 0 off/frozen/locked can do fun stuff too.
Confusing, huh.
