Alfred.NESWADBA
en respuesta a: Anonymous
>> Appologies if my English is not clear, it's not my mother toung
No problem, I'm also not an English native speaker :cara_guiñando_un_ojo: But we needed to clarify what you did and so thank you for your screenshot!
And most important: have you seen the error message in the command line (within your screenshot):
>> C:\Program Files\Autodesk\AutoCAD 2016\acdwfmarkupcore.crx is an invalid ARX file.
The only thread I have found with that message (>>>click<<<) also first recommends to run a repair install and - sorry to say - the guy who had the problem solved this issue only by reinstalling the operating system.
I would first rename the acdwfmarkupcore.crx file to any other extension, so AutoCAD can't find it. If you don't need the markup support maybe you can then use PDFATTACH without issues, if not run a full repair installation of AutoCAD and hopefully this works (make sure you have full admin permissions, and antivirus is turned off during that process).
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
