12-14-2023
10:07 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-14-2023
10:07 AM
In AutoCAD, you can create a table to serve as a sheet index by utilizing the DATA EXTRACTION command. Begin by opening your drawing and invoking the DATA EXTRACTION command. Select the layouts for extraction, specifying 'CTAB' and 'Title' as data to be extracted. Choose output options, either creating a new table or adding to an existing one. Insert the table into the drawing at the desired location, and format it as needed. To update the table with the latest information, right-click on the table and select "Update Table Data." This automated process allows you to dynamically maintain a sheet index based on layout names and titles without using the Sheet Set Manager.
