- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Connection error, link may be broken
Hello everyone.
The problem I am seeing is with an autocad file in sharedpoint that gives me the following error: Failed to connect, Link may be broken
From what I can see, when I close the banners that appear I can work normally but they appear again when I open the CAD. From what I see in xref, all references are fine.
I have also already tried these solutions:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Failed-to-Connect-... AutoCAD.html?_ga=2.120741582.733195026.1702171633-1209385761.1700242418
If I move the file from sharedpoint to my destok (local computer) the banner does not appears. But it only happends when I open a file that I'm working on, not the other CAD files in the sharedpoint.
So, Why it only happends with the file I am working on and not with others files?
