- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have recently updated to the 2024 version of AutoCAD. I have two questions.
1) When I click on a dimension it wont allow to me grab and extend the dimension. I have all of the snap options on. How do I make this happen in 2024?
2) When I use the move command it does not allow me to add objects under the same move command. For example if I use move and highlight elevation A but I did not highlight the dimensions and need to move those as well, it will not allow me to move/add the dimensions under the same move command. I used to be able to do this. Any ideas?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
1) Does this happen in ALL files, or just this one with Layer 0 or DEFPOINTS locked/frozen/turned off?
Or is your PICKFRIST variable just turned off?
2) PICKFIRST and PICKADD set to the defaults listed in HELP? they need to be.
Perhaps this is showing for you
