Alfred.NESWADBA
en respuesta a: cturlington
>> I have two surfaces
What exact object type are they? When you select them and look to the property window or when you run command _LIST ... what type of object is shown?
>> I have tried using the Sculpt command
Do you mean SURFSCULPT? Because I don't know a command SCULPT.
In case of SURFSCULPT: Therefor you need to have a watertight situation. If your planed surface is above the existing ground and you don't have side-walls to close that 2 surfaces to a watertight (virtual) volume the command _SURFSCULPT can't bring you a 3D-Solid.
>> I have Map3D and Navisworks software at my disposal if those would be a better choice?
The best choice would be Civil 3D for that job.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
