Kent1Cooper
en respuesta a: leeminardi
That's the idea from Message 2.  A couple of suggestions:
Also re-JOIN the source en1 and en2 Polylines back together.
Go to the nearest vertex to the pick point for the Break, so that the Joined end results don't have an extra vertex at the pick point.  [That has the risk that if there's a non-tangent change in direction there, the Offset results won't touch at their ends, so a fuzz distance would be needed in the JOINing.]
@ltastan1 , would your originals ever self-intersect more than once?  Depending on the specifics and exactly where you pick, this approach would sometimes not have the desired result on such a Polyline.
Kent Cooper, AIA
