chriscK8R5W
247 Vistas, 2 Respuestas
Is there a correct way to shut down?
I have noticed my drawings missing work after the drawings are reopened the following day. I save and close but something seems to still be missing. Is there a hard save you can do before you close for the day?
Valentin-WSP
en respuesta a: chriscK8R5W
@chriscK8R5W ,
Closing may not be your issue.
Take a look at this:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
najax43826
A save is a save. There is zero reason (AutoCAD related) why your work would not be getting written to the file on disk. What location are you saving to? A network share? If so, what are the specs on this network share. AutoCAD is real particular about certain technologies and hardware ( see this ).
Related: I'd ensure ISAVEPERCENT is set to 0, and keep an eye on your Windows Explorer when you save and make sure the DWG file time actually changes when you save. If you ever see it disappear or not update, look for a new .TMP file in the same folder.
