Kent1Cooper
en respuesta a: leeminardi
@leeminardi wrote:
... I suggest creating an offset to  both sides and delete what you do not want and join what you keep.
That doesn't give complete "coverage" of the desired path.  In this analagous situation, white is the original, red the result of Offsetting to one side, green to the other:
If OFFSET's goal is a result in which every part is the same distance away from the original, it can't fill in those gaps, because the entire length of each missing part would be at incorrect distances from the original.
Kent Cooper, AIA
