Kent1Cooper
en respuesta a: tranhang13798
If you mean that you want to be able to show the 270° angle, like this:
you can do that by not just selecting the lines, but using the specify-the-vertex option:
DIMANGULAR
Select arc, circle, line, or <specify vertex>:  {Enter to accept specify-vertex option}
Specify angle vertex: {pick at intersection or apparent intersection}
Specify first angle endpoint:  {pick on rightward line}
Specify second angle endpoint:  {pick on downward line}
Specify dimension arc line location or [Mtext/Text/Angle/Quadrant]:  {the usual}
Dimension text = 270
Kent Cooper, AIA
