emma_stuart20
272 Vistas, 2 Respuestas
I was Drawing in 1:25 and its now changed to 1:1
I'm Currently doing a drawing for TAFE and I have to use the scale 1:25 to draw, I've been working on this for a few days now and I just went on today and its changed to 1:1? I really do not want to restart this drawing, its dure very soon too. Is there a way to fix this, or see if most of my drawing is in 1:25??? I know I definitely used 1:25 at the start, I really hope I don't have to restart, any advice is great thank you! :cara_con_una_leve_sonrisa:
Etiquetas (1)
paullimapa
en respuesta a: emma_stuart20
Unlike manual drawing when you draw on the computer you should be drawing everything at 1:1 which is the full actual size. This is one major advantage of drawing using the computer.
Then when you’re setting up to place what you have drawn on one of the standard paper sizes like A0 to A4 then you go to layout,  create a vport using the Mview command and set a scale like 1:25 on the vport looking at a view at the model. You should search online to give you more detailed instructions on how to go about doing this in AutoCAD
Paul Li
IT Specialist
@The Office
Valentin-WSP
@emma_stuart20 ,
Welcome to the AutoCAD forum!
You can post your drawing or take a look at the suggestion from this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
