arshadmirza786
540 Vistas, 2 Respuestas
Convert dwg Imperial.dwt to Metric.dwt
My colleges has created so many dwg on Imperial.dwt assuming 1 imperial unit = 1m
Facing some poblem when inserted these dwgs. to metric.dwt based dwgs
Is there a easy way / lisp to shift the imperial.dwt based dwgs to metric.dwt based dwgs
cadffm
en respuesta a: arshadmirza786
Imperial.dwt and metric.dwt doesn't sound you are on AutoCAD!?
They should set up Measurement to 1
if they want to work in metric always
And QNEW should refere to the metric template.
Files
For plane autocad/lt:
Open the dwg file
Set Insunits to the right value
Reload all linetypes from acadiso.lin
Purge all
Now, there are one thing:
Your hatch patterns are based on imperial
but I don't no a public and 0$ tool to change this.
(Workarounds are possible)
And another thing: I think most of the blocks are not set to a metric unit,
this isn't a problem, but good to know.
You can share both .dwt, so we can see whats going on.
Sebastian
Valentin-WSP
@arshadmirza786 ,
Take a look at these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
