cwkbpa
en respuesta a: Matt.PayneENS6Q
@Matt.PayneENS6Q
Thank you for bringing this back into the light.  There has been a fix and I'm happy to share it with you.  It has to do with the SSL Decryption Exemptions to get through the firewall you have.  Below is the exact email AutoDesk Support sent me.  Administrative abilities are needed to do anything she speaks of here.  Also, the Driver  .arx wasn't allowed to be attached.  I'm not sure how else I can send it through here.
Hope it helps.
--We have been following these cases and finding that (in most cases) The maps are displaying after adding the following autocad domains to SSL decryption exemption( autocad.com, misc.autocad.com, and developer.api.autodesk.com)”.  If you still have this issue after setting up these exceptions, there is a driver that I can have you run and it will show exactly where the block is occurring.
Claudia Martinez
Customer Technical Success, AutoCAD Map 3D Actions
Autodesk, Inc.
221 SE Ankeny St.
Portland, OR 97214
www.autodesk.com
