345 Vistas, 1 Respuesta
COGO Alternative for AutoCAD 2016
I am a landscape architect trying to create spot elevations that are points with a text attribute attached. My surveyor uses Civil 3d and I came upon COGO points and thought it would be a great feature for my use! Is there a feature similar to COGO Points in AutoCAD 2016 where there are two objects (a point and a text object) but are unique objects and can be placed all over my grading plan and positioned to not interfere with linework? There doesn't have to be a z value attached because the value would inform the contractor of the z elevations.
What i dont want to have to continue doing is; creating a block that contains a point and a attdef because i want the ability to rotate move the text without creating a new block, or having two seperate objects that move independently of each other.
dgorsman
en respuesta a: Anonymous
Have a look into dynamic blocks (and possibly annotative blocks as well).  Move, rotate, and other features abound.
