pendean
en respuesta a: TOMLANG7190
@TOMLANG7190 wrote:
Plotting to PDF or DWF via sheet set manager.  In the past, in page set-up manager, I'd set the plotter to DWG to PDF.pc3.  From the SSM, I could publish to either PDF or DWF without changing anything.
I noticed that when I added the Bluebeam plotters, all the default ACad plotters disappeared, and I had to restore the DWG to PDF.pc3 one.
Is there a way to just restore all the original plotters?
Looks like you really need BLUEBEAM support over here
You can always remove your BlueBeam and/or RESET or REINSTALL AutoCAD to get everything back to OOTB. Your IT person/folks can help you with that if you're in a locked-up user account.
