Bernardo-leon
394 Vistas, 5 Respuestas
Line weight not showing
On autocad I set up all my layer properties with the color ,line type and line weight .once I get to drawing whatever lines and I want the line weight to show I press the line weight button and my lines will disappear and just show me the dots where the points are at .
ennujozlagam
en respuesta a: Bernardo-leon
try to type LWDISPLAY and set the value to On (or 1)
cadffm
Install the latest update!
Sebastian
paullimapa
share your drawing
Paul Li
IT Specialist
@The Office
Valentin-WSP
@Bernardo-leon ,
@Bernardo-leon wrote:
... the line weight button and my lines will disappear and just show me the dots ...
Try the suggestions from these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
vinodkl
Hello @Bernardo-leon
This is bug in 2023 version and it's fixed in 2023.1.4 Update. Kindly update your AutoCAD to fix this issue.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
