clindner
en respuesta a: Ali-pk
A simple find/replace (via FIND) may suffice. You can be selective about what pieces of text get updated (instead of the entire drawing).
Or explore the use of FIELDS. Establish one of the '5's' as your main text. For the other pieces of text, edit the other text to be fields that reference ("point to") the contents of the "main text".
In the image below, the 'main text' is the one at the top. The add'l pieces of text are fields (hence the gray background). They will all update (after a REGEN) to reflect the contents of the main text.
Please use the Accept as Solution or Kudo buttons when appropriate
Chris Lindner
CAD Technology Consultant @ onebuttoncad.com
AUGI Board of Directors
