10-13-2023
06:39 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-13-2023
06:39 AM
Ipt to dxf/dwg script?
Hello, if someone could help me I would be very thankful.
I need to convert .step / .ipt files into .3DS, .DXF and .DWG files.
The .DXF and .DWG needs to be in 2010 format as otherwise it wouldn't work for my clients.
The problem is that right now the process is:
- Open 3ds max
- Import .step / .ipt
- export into .3ds
- Open AutoCAD
- Import the .3ds
- Save as .dxf (2010)
- Save as .dwg (2010)
And I need to do this for hundreds of files.
What I'm looking for is some program that would make this easier. Or a script that could make this automated.
Thought of using fusion 360 so when I make a model I can export it to at least the .dxf and .dwg files. But that doesn't solve my issue with the files I already get models for and for some reason you can't export in the 2010 version of dfx/dwg.
Thanks for any help
