Kent1Cooper
en respuesta a: martin.hong
Would the Civil3D Forum be a better place to ask this?  I haven't worked with TIN files, so I don't know what they're like.  I assume their elements are surfaces of some kind that can be at least slanted in the 3rd dimension, but can they also be non-planar [i.e. warped]?  Do you want to place Blocks out in the middle of an element where there is no endpoint or intersection or some such thing to Osnap to?  If the elements are all planar, I think there's a way to calculate where a vertical at a given XY position would intersect the surface, to get a Z value from.  But if they might be warped, I'm not so sure.  Might Civil3D have a built-in capability to find the point on the element?
Kent Cooper, AIA
