10-12-2023
08:44 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-12-2023
08:44 AM
INSERT command (which can be triggered from TPs and ADC and other methods) always asks you for a Z, you could just enter that info at that time.
Are you just eyeballing the x,y location? Then it's tough to eyeball the "z" from a 2D above view with UCS and PLAN set to all that flatness.
Also... much like placing blocks in x,y at a very exact location, to do it in x,y,Z you can also "osnap" to an element at the Z elevation you desire. That's one way to do it that is very quick.
And... before block placement, you change your active Z elevation to what you need it to be first then drop it at the x,y you are eyeballing. Look up ELEV command.
