10-12-2023
08:07 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-12-2023
08:07 AM
Can you place a block on a tin surface and have the same z value as the surface elevation?
Hi all,
Basically right now I am placing a lot of tree blocks on a plan and they all need to be at a specific elevation. Currently I am placing the block, adding the spot elevation, then manually changing the z elevation under each properties to match the spot elevation.
Is there a way to quickly place the block so that wherever it lands on the tin surface, its z value matches the exact elevation at that point on the surface?
I attached a pic for reference.
Thanks!
