Valentin-WSP
en respuesta a: jghughes
@jghughes ,
Sounds like you are doing everything correct; however, I get the impression you are trying to insert the Title Block already containing a block reference of an attribute definition - which will not work [like a block within a block].
Instead, create your Attribute Definition (ATTDEF Command) within the Title Block [NOT  a block reference], then insert your Title Block.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
