jghughes
397 Vistas, 4 Respuestas
Assistance with creating text blocks
Hi All,
Although I can "fudge" my way through with this issue, I'd like to learn how to do it properly.
I have an existing dwg title block that is missing text fields for the section for reference documents, which I now want to add. I've created a block for the text, created tags, synchronised the block, but still no success. I see that when I click on existing text blocks in the title block, they open in the Enhanced Attribute Editor, but this doesn't happen when I click on the new block I've created. I suspect I've done something wrong when setting up the attributes. I've read through a lot of blogs/sites today to learn how to do this, but I suspect that it's something too basic for people to devote time to. Any help would be greatly appreciated please.
Valentin-WSP
en respuesta a: jghughes
@jghughes ,
Sounds like you are doing everything correct; however, I get the impression you are trying to insert the Title Block already containing a block reference of an attribute definition - which will not work [like a block within a block].
Instead, create your Attribute Definition (ATTDEF Command) within the Title Block [NOT  a block reference], then insert your Title Block.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
paullimapa
share your title block so we can see what you've got
Paul Li
IT Specialist
@The Office
jghughes
en respuesta a: Valentin-WSP
Bechtel Level 3 - General. Non-Confidential Business Information.
It worked, thank you so much.
jghughes
