10-04-2023
01:04 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-04-2023
01:04 AM
I assume when you write “plotting” you mean “drawing”
Unfortunately the only way to set up drawing units is with UNITS command. Once selected all drawing input command are based on that. So since you chose decimal, AutoCAD won’t recognize the inch “ symbol when you type that into the command line for distance entries. Now you can setup a dimension style to show both the current drawing unit setting and an alternate unit setting.
